Piston Help......
Results 1 to 14 of 41
Piston Help......
    Placerville/So Cal
    Default Piston Help......
    I dropped a valve and put a hole in the piston. It was a .30 454 I ahve no idea what these pistons were. I was hoping maybe someone might know who made these. The only markings on the pistons is the bottom, where the number 252-97 is stampted. Any help as to who made these would be appreciated.
    Gone
    Sparks, Nevada
    You need to clean one of them up...and take a picture. Clean the top real good as there may be a number.
    I don't think the other number you found will do much good.
    Placerville/So Cal
    When I had the motor apart last time, there were no makings on the top of the pistons. Those numbers are the only markings to be found.
    Senior Member gregb's Avatar
    Redondo
    If it's a cast piston I'd take it to a GOOD machine shop if you cant find any numbers on the top of the piston, they might be able to identify it or even have one in stock.
    Placerville/So Cal
    Default pics
    This is the only marking to be found. If there was one on the top, I think someone filed it off
Name:	Cal's Pics 2 040.jpg
    well it's forged, now how about a pic of the top, there just aren't that many configs those pistons came in for a given cid, should be fairly easy to ID, appears to be a flat top, the way it's setting, but not certain
    Placerville/So Cal
    No, It is a dome. I just have a pic os the sies and the tore up top. I'll Post those up for you.
    Looks like a TRW to me but thats a guess, there should be some #'s on the top. I have a set in the garage and they look really close.
    Placerville/So Cal
    Default more pics
    [IMG][/IMG]
Name:	Cal's Pics 2 044.jpg
ID:	8480   Click image for larger version.
Name:	Cal's Pics 2 043.jpg
    I believe this it, hard to tell by that pic, need something of the top regardless the condition would be helpfull.
    http://store.summitracing.com/partde...0&autoview=sku
    prolly as close as you are going to get and lucky for you they are sold individually
    Placerville/So Cal
    That link did not work. I'll post up a top pic in a minute.
    try the link again, I fixed it heres your two choices, do you think the dome is a 1/4 inch high, or more like .100 high the 2399 has a .100 dome, and the 2349 has a .250 dome the 2399 was more OEM with a press pin, 2349 is a press or float
    Placerville/So Cal
    Thanks, it worked. I;ll have a pic of the top in a few.
    Cantard 71hallett's Avatar
    snow bank
