enderle fuel returns
Results 1 to 9 of 9
    92 KURTIS RUNNER BOTTOM
    Default enderle fuel returns
    Okay installing a bird catcher, do i run the return lines back to the tank or can I return them back to the fuel line before the pump and tee them in right there, there will 2 lines number 6's, the safety valve after the pump has the enderle hard line kit that returns right back at the pump, so why cant the others go there to?
    A ARMED SOCIETY MAKES FOR A MORE CIVIL SOCIETY
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Those pumps have a hard enough time picking up fuel normally. Don't confuse the pump on which it should pick up. The returned fuel or tank supply.
    Don't do it mon.
    Some pumps you can return to the pump inlet but not these.
    Don't do it mon.
    Agreed, by pass back to the tank.......Don't confuse the pump, and the pressure by pass with aireated fuel. Back to the mass, let it cool, and run it!! Never set a pressure by pass deadheaded, just like an Oxy/acc rig, have an open orafice while establishing a working pressure...........More accurate, and easier to duplicate..............MP
    LOUD BOATS SAVE LIVES
    adjones419 Wet-n-Wild's Avatar
    Shiloh, IL
    I run a loop line from the 3-way fuel shutoff to the pump inlet, but that's just to keep the pump lubricated a bit while it leans out before I shut it down. You could also run that directly back to the tank. I have a Nitro "K" barrel valve, so I have 2 lines returning to the tank from the barrel valve. Scroll down to the bottom of this page and it has the diagrams for the Enderle fuel systems, depending on which barrel valve you have.
    Adam
    Hallett 210
    Quote Originally Posted by Wet-n-Wild View Post
    big time, depending........not to mention which fuel.........
    I going to be setup for gas, I am running a -10 to the pump, -8 to the barrel valve and 2 -6 back to the tank now, running the hard line bypass at the pump with the emerg. shut-off, now the big question, it is getting flowed right now and I am thinking the 36 nozzles are to big, what I was told by a freind who has a bug catcher is run 30 nozzles and start with a 140 pill and work down to a 130 if needed ,does this sound like Im on the right track? Thanks, atleast so far everyone is saying the right thing
    Senior Member superdave013's Avatar
    Quote Originally Posted by BAD REACTION View Post
    it this is a blown deal run a -12 to the pump.
    Quote Originally Posted by superdave013 View Post
    i have a 3/4 outlet on the tank, and my line will only be 15" from the tank, still run a -12? thank you
    1071 mooney ham running 15% over
    Gone
    Sparks, Nevada
    I sure would. Lotta guys run a #16 but I think that is overkill.
