Hampton blower
Results 1 to 14 of 31
Hampton blower
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    Default Hampton blower
    What can you guys tell me about a hampton 8-71 alcohol blower. Any good?
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    ..... rivergames's Avatar
    Los Angeles / Parker
    i have a hampton 8-71 blower on my setup. Runs like a charm. The only difference is that i am running gas and not alky
    Gone
    Sparks, Nevada
    Nothing wrong with a Hampton blower. He is one of the old guys like Mooneyham, Mert Littlefield etc.
    Byron, CA
    i have a retro 14-71 hampton...very nice piece!!!...nothing wrong with them.
    AZ, Queen Creek
    Ya I called today and talked with Don personaly and they seem like good people. There is just so many different brands, cases, rotors, etc. I'm in the process of building a blown motor for my hydro. What size would you guys recomend going with, the 8 - 71 gas would suite my needs I'm sure but buying it new should I go big and never worry about wanting more. It going to be BBC either a 468 of a little over 5 cubes but nothing like a 580. These are question I know only first hand experience can ask but all input I'm putting into word and saving , thanks kyle so lets hear it, no reply is to long
    ___________
    Gone
    Sparks, Nevada
    Always a tough answer. But consider some things.
    Longer than an 8/71...you gotta run an offset mag. More expense.
    If you build the motor effeciently in the first place...you don't have to boost it that much.
    If you go quicker than 8 seconds in racing...you have to have a capsule.
    Only you know what performance you are looking for.
    You can always just add alcohol if you go injection for more power.
    If you can't hit 8 seconds with an 8/71 on blown gas in a hydo.....you are doing something wrong or it is a boat problem.
    Hope that helps.
    AZ, Queen Creek
    Hope that helps.
    The motor was sold to a seperate buyer. The boat did 154, with a lanco 48 gears, and a 7.90 468 chevy blown alc
    Answering some of the questions to help me narrow it down I'm putting a birdcather on, no carbs on this one. I think I'm going to just do vp fuel, alcohol getting pricey that way I could still putt around at the lake
    ___________
    Gone
    Sparks, Nevada
    So you got a proven boat....should be an easy deal.
    Here's maybe a little bit relative example of a hydro:
    "Drastic" boat (formerly the Drastic Plastic fuel boat. Heavy sanger)
    468 inches, TRW piston 8.1 / steel rod, cast iron 990 heads.
    6/71 hampton gas blower.
    2 speed owens but left in high gear only. No shifting.
    Boat ran 9.0's most anywhere. Blower OD % 10-14% over.
    If I let him shift the 2 speed...we could go 8.60's.
    Very basic motor..lasted for many years.
    AZ, Queen Creek
    Ok well with that being said I'm honestly thinking 518, hampton 8-71, gas, birdcatcher, hopefully the boat will still run respectfully .
    ___________
    i've got a birdcatcher set-up that i need to trade for a dominator set-up
    AZ, Queen Creek
    Whats the reason for wanting to trade the bird catcher as appose to carbs?
    ___________
    pretty mch the setup i have. except i hve to 850 holly's on top instead of the birdcatcher and have a richard lee innercooler. Your boat should run great
    Senior Member bordsmnj's Avatar
    garden grove / emerald cove
    i wonder if Hamptons new curved rotor deal fits in the same housing?? nice stuff.
    Quote Originally Posted by Rep. Joe Wilson (R) View Post
    YOU LIE!!!!!
    Big Boys Toys Murray PE 857's Avatar
    I had a 505 BBC w/ Dart alum heads and a Hampton 8-71 on this boat. Alcohol injected. It ran consistent 8.0's and ran as fast as 7.56. Similar to your anticipated setup. Then I built this motor 604 ci, 14-71 and I'm not even sure what to do with it now. Too much of something. dhttp://www.performanceboats.com//attachment.php?attachmentid=8568&stc=1&d=121090312 5o
