meth injection on Turbo motor?
Results 1 to 14 of 32
    Default meth injection on Turbo motor?
    can meth injection eliminate the need for intercooler? how much meth is used? how much boost can you run? how do you tune it?
    okie, lake Texoma
    Quote Originally Posted by OkieDave View Post
    Yes it can, just dont let it run out. Talk to Rodney at AIS, he's the best at this and can give you the tune.
    The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
    H8-2-W8
    [email protected] first pass
    Jan 2011
    Mickleton, New Jersey
    yes, put it on a dyno
    thats wat i did, no i.c. and a.i.s. 3 nozzle injection with a nice 5qt tank that should last the day.less than 13inches of charge pipe between my turbo comp outlet and the hat inlet, throttle response is nasty on the trailer, cant wait for the water to warm up
    Member Mt.Man's Avatar
    Bass Lake California
    Default Meth
    Where do you inject the meth on an old Race Arrow, Rajay, draw thorough, twin holley, i/c setup. Running 15lbs boost with 100ll fuel? Is it best to buy the the entire kit or custom build to your needs? Thanks for any information or direction. Bill T.
    okie, lake Texoma
    Quote Originally Posted by Mt.Man View Post
    Like I said, best to let Rodney setup your system. There are to many variables & setups out there for a one size fits all system.
    H8-2-W8
    Just my 2 cents on the subject and I am sure(think?) that Hass and Impatient will back me up on this. Nobody has mentioned water in this thread at all. Not sure if it is assumed or if someone is actually thinking 100% pure meth injection. Although Rodney is damn good at what he does and sells, and one hell of a nice guy, he isn't a magician.
    His systems, and everybody elses are based on a 50-50 or less mix of meth/water. Two things happen when you go passed this. One, the mix can become flammable. Its still pretty damn safe at 55-45, maybe even 40-60. But really, that is the point. As the mix gets richer, it gets harder and harder to jet the carb. Every drop of meth enrichs the total A/F ratio. A little enrichment under boost is good, a lot, not so good. If you attempt to jet for pure meth you will have to lean do the un-injected mixture to be in the ball park when it arrives. The amount you inject will impact the A/F. If you inject a tiny amount, you don't jack the overall too badly, but you miss out on the cooling. If you dump it in there, your A/F goes to hell. You're much better off in the long run using a 50-50 than straight meth because you can flow more without screwing up the A/F.
    If your running a closed looped EFI, that a different story.
    See Hass, there is some benefit to EFI. Like 100% pure meth injection under extreme boost! I'll take that over an IC or a 50-50 anyday.
    Damn, 100% meth and a knob. Now thats an unbeatable combo. Peanut port heads and stock hyd cam here I come!
    sacramento
    X 2 ! thats wht they told me . i run one on my truck . having problems now. when the pump is off it still draws water & causes a bad idle. way cheaper then racing gas!!!!!
    Quote Originally Posted by turbo wog View Post
    thats why they invented check valves
    sacramento
    where could i get the right one? i just found out today that i needed one.
    Any of the ones that Jegs and Summit sell should work. I used Jegs and they are pretty damn fool proof. They have them all the way up to -12
    LINK: Jegs check valve -6
    okie, lake Texoma
    Exactly correct. The mix is the way to do it. Actually -20 windshield washer fluid. It can be bought anywhere and is cheap.
    H8-2-W8
    Jun 2011
    spokane, wa
    Last season I ran an AIS water/meth kit on my 14-71/565 combo, I was able to run 10lbs of boost and a 200 shot of nitrous all on 92 oct. pump gas from the local chevron. It was a dual nozzle set up that I installed in the carb adapter plate with a 3 gallon tank, I would use just over 2 1/2 gallons to 28 gallons of gas. I bought a drum of vp methanol and mixed my own 50/50, it worked awesome and everything in the engine looks great!!
    Senior Member slow67's Avatar
    DFW
    Alkycontrol is one of the few systems rated for 100% meth use. One downfall of meth is yes, its flammable, and if you have a BOV, it WILL mist out it when it opens. Not such a problem with jets, as many won't just chop the throttle anyway, so they don't run BOVs.
    One problem with water is, you can only inject so much (on a particular combination). In theory (negating any distribution problems) you can just keep adding meth (keeping your overall fueling in check with your carb/EFI).
    Also, now a lot of people use solenoids instead of check valves, as the pump can take a second or 2 to bleed off its built up pressure (over-running a check valve). Not really a huge problem unless you are running pre-turbo injection.
