Oil Pan
Results 1 to 2 of 2
Oil Pan
    Senior Member SHADOW 21's Avatar
    Sep 2009
    GREENSBORO, NC
    Default Oil Pan
    If you have a 10 quart oil pan, does that mean the motor should hold 10 quarts of oil. I put 8 quarts in the motor and the oil level is on the full mark on the dip stick, I have started the motor to fill the oil filter.
    Quote Originally Posted by SHADOW 21 View Post
    No, should be much better off only filling to the mark. The mark should have been checked while the pan was off to verify where it put the level in the pan.
