Dart Big M Block Head Gaskets
Results 1 to 3 of 3
    Nov 2009
    Default Dart Big M Block Head Gaskets
    Can anybody tell me which is the right head gasket for a dart big m block 4.5 bore with afr heads, dart said felpro 1047 and afr said felpro 1017
    thanks john
    Quote Originally Posted by sport View Post
    thanks john
    The two are basically the same configuration, but the 1047 is considered suitable for marine use because it has a stainless steel core. Both have the 4.54 bore. The 1017-1 and 1047 are .039 thick, the 1017-2 is .051 thick. The 1017 has two coolant holes per end, the 1047 only one. Either will work on your block just fine.
    Nov 2009
    thanks for the help
    John
