who is running a dominator?
Results 1 to 14 of 29
    SDBA #819 vdrivegrimes's Avatar
    Oct 2011
    Default who is running a dominator?
    who is running a 1050 dominator carb? would there be any benefit for me switching from a 4150 flange QFT 1050 to a holley dominator?
    motor is just a hair over 12-1cr 496 with rec port heads with 345cc runners. no clue on hp
    Senior Member dankdave79's Avatar
    Sep 2010
    I have a 1050 for sale in the parts section if ur intrested. Ran great on my 588 . I took it off for a bigger 1150
    Oct 2011
    Quote Originally Posted by dankdave79 View Post
    it was your carb that got me thinking about all this
    Concord, CA
    Default dominator
    I run an 1150 on my 496" 13.9-1 comp. Real happy with it.
    Jerry
    Quote Originally Posted by vdrivegrimes View Post
    I think the key question is, what kind of RPM are you turning?
    With those heads you might as well.
    [email protected]
    Ohio
    Thats some thing I've wondered. QF has a 1050 dom and a 1050 4150. I assume they both flow 1050 cfm. So, what would make the difference as to which one to use?
    Tim
    Feb 2012
    OC, CA
    I think going from a 4150 flang to a Dominator flang will be the big difference. Both carbs flow the same but the 4150 flange would be more restrictive.
    Quote Originally Posted by Ol Blue View Post
    Carbs are rated by a given pressure drop, regardless of their falnge bolt pattern,
    They can both flow 1050 at the same pressure drop, and I would rather have the 4500 dominator than the 4150 at anything over 850. The largest throttle blade on a 4150 is 1 3/4". To get the CFM up, they have to open up the venturi. The shape os the venturi is less than ideal. The diameter to height is compromised. This makes the carb less responsive at anything less than WOT. Whereas the Dominator uses a 2" throttle blade and much better shaped, taller venturi.
    The 1050 QF 4150 uses the same main body as the Holley 1000 4150. Both carbs are fine for use when there is a throttle blade diameter rule that restricts the blade to 1 3/4". But anytime you try to gain that much CFM by way of a venturi, you're making compromises.
    In almost all cases the dominator will be a better carb than the 1050 4150. It may not be any faster, or make any more HP at WOT, just better throttle response and better part throttle metering.
    Oct 2011
    thats some great info
    I couldn't disagree with this more. When you leave out any mention of the booster you're only telling half the story. There are plenty of examples where a 4150 will get down the track quicker than a 1050 on a given combination.
    The 1050 has a venturi of 1.690, the 1000HP has a venturi of 1.560. The smaller venturi will have higher airspeed at the same flow rate...higher perssure drop, better signal and atomization. Always. The 1050 is great for WOT but no where near as clean or responsive as a 1000hp.
    Tim
    Application.
    Southwest corner AR
    So with a T/R this is the same?
    WT
    WFL Crew!!!
    Technically, yes. Again, it's all application specific.
