Gentleman I`ve got a head gasket question
Results 1 to 14 of 18
    Default Gentleman I`ve got a head gasket question
    This last season I`ve tired the fel pro gaskets on my BBC it`s a dart block with Merlin heads I think the part number was 1157.. long story story they seem to be leaking between cylinders each time I`ve pulled the heads. I`ve place a straight edge on the block as well as the heads and their both flat... These gaskets are a 3 piece deal that is riveted together and I think they suck ass compared to other`s I`ve used in the past... I need a recommendation for the replacement`s that I should try this go around... thanks
    copper
    Dec 2010
    Sapulpa ok
    copper
    X2 Never a problem that wasn't tuner(me) related.
    Quote Originally Posted by piston in the wind View Post
    I don't know of an 1157 FelPro, but I've heard others say the Felpro MLS were thin between cyl's. I've never seen that problem with Cometics. Depending on the application, you may not even need a MLS gasket. The Felpro composites worked awfully well for decades before MLS gaskets ever showed up. Is this boosted, or real high rpm/high compression? If not, you might just go back to the traditional 1017 or 1047/1057 (large bore) for marine.
    Atlanta, Texas, United States
    I have seen some of the Felpro MLS type gaskets seep a little to the point that I no longer put them on direct. I now drill out the rivets and spray each layer with a gasket spray sealant and then stacked them in the original arrangement on the engine. This seems to have cut down on gasket seepage problems.
    Gear
    PS: Once they begin to leak under combustion pressures, like between the cylinders, it appears they begin to erode or distort the surfaces. If they are sealed good in the beginning, then they will stay with you. I don't particularly recomend such, but we had an engine that we were trying multiple combinations on a couple of years ago and had the heads off several times and just cleanded the gasket, resprayed them and kept going.
    The single most important thing with any of the MLS type gaskets is FINISH!!!!!!! It not only has to be dead ass flat, it needs to be very very smooth.
    Some time ago Steel brought up the point of the machinist himself. The right type of maching, with the right cutter, run with the right speed can still result in crap sealing if he tilts the cutter head too much to avoid a back cut. This results in a dished or scooped cut, and it just so happens to fall right down the center of the head, and really shows itself between cylinders.
    The second most important think is CLEANLYNESS!!!!!!! It has to be spotless. I run a razor blade across the deck like I am scrapping paint till I am crtain the is no foreign matter on the deck, then wipe it down with iso alcohol. You absolutely can not get the surface too clean.
    The eary FelPro MLS gaskets had a sticky sealant on them with a waring not to touch it, and to install the gasket immediately after removing package. Now, they are just like a Cometic. I use a sealer on this type. I like Valco Hylomar Spray, or brush. Its not easy to find and its a little pricey. The next best thing(IMO) is MoPar #4318035AA. Like Gearhead posted, if you really want it sealed, take the rivots out and spray a both sides of the out layers. You can actually just remove the rivots for one side and fan the gasket open and spray it.
    However, like Steel posted, do you really need a MLS?If I didn't need them I wouldn't run them. The Perfomance FelPro gasket is a damn good gasket and its almost dummy proof. They are also much friendler to alum heads. I have hammered the hell out of the PERFORMANCE Felpro composite gasket and never failed one between cylinders. It was always at the top of the cylinders with the missing top bolt.
    Bottom line, if you leaking between cylinders, double check the block CLOSELY, or change gaskets to the composite type if you aren't running seriously high cylinder pressures.
    Quote Originally Posted by tkriley13 View Post
    Have you looked into these yet.
    https://www.flatoutgroup.com/docs/20...alog-Cover.pdf
    Tri-Cities, TN
    Cometics. I just don't have any issues with engine builders or end use customers.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Thanks guys we`re going back to cometics but might have to run another set of fel pro to get thru the first race but I guess I should`ve put some Indian slack crap on the gasket and it might not have leaked so I was told. Also it wasnt as bad as I thought accordling to place I use, so that was good news. New blower and MFI and 20 ibs of boost it should move I hope.....
    Once again thanks for the education...
    waterloo
    Cometic has their new bitchin' 4 layer gasket for high boost applications. Like 20 psi.
    Check out their web side.
    Wags
    I forgot what they call em. It isn't "the bitchin series" HA
    Default 1017 vs 1037 Felpro FYI only...
    Something I discovered quite by accident when trying to get this last engine, (a gen 5) to seal along the bottom water passages, is that the 1017 is not designed for the gen 5, but the 1037 will work on all, MK IV, gen 5, and gen 6 engines and heads........I didn't have a 1017 to compare side by side so I'm not sure how one works on everything, and the other just MK IV...Also, the 1017 has a 4.540 bore, quite large for a 4.310 cylinder, while the 1037, which is also recommended for Marine use, has a smaller 4.370 bore which is much closer to the actual 4.25-4.31 sizes.....
    Ray
    PS the sealing issue was because of the customer's desire to use all GM pieces, including sticky head gaskets, that came on the 454 HiPO factory deal.... The problem was the gen 5 block has triangular water ports along the bottom, but all the gaskets have a smaller round hole and the gen 5 block/head only has about 1/4 to 5/16ths inch sealing area below those ports.... The GM gasket leaked water out between the head and the block, just a few drops, but leaking none the less.... The Felpro 1037, and some Permatex #1 applied along that area sealed it right up..... I normally add a small bead of high heat silicone around all the water ports on marine stuff, both below the gasket, and above, directly under the head... Never had an internal leaking issue, (except twice with copper gaskets), and after well over 100 assemblies, NEVER had one leak like this one externally!!! Then there was an issue with the gen 5 timing cover and the front motor plate, and of course the "stinger" deal I started a thread about....But, those are another story......
    LOUD BOATS SAVE LIVES
    Ray, put down the tools and step away from the engine. That is all COMMON knowledge.
    Here is the site that will explain it all for you. Read carefully and pay attention and it is pretty clear.
    Never ever use a gasket designed strictly for a MK IV on a Gen motor or you will fry the damn thing. BUT, you can use any GEN gasket on a MK motor.
    Pay very close attention to then water ports at the front of the block. The MK motors have no open ports up front, the GENs do. YOU MUST!!!!!! use a gasket on the GENs that does not allow water to pass thru that front port. On the MK it doesn't matter if there is an opening in the gasket, because there is no opening in the block!
    Pay very close attention to page 2
    LINK: FelPro tech
    Default Common?
    [QUOTE=gn7;1601239]Ray, put down the tools and step away from the engine. That is all COMMON knowledge.
    Yeah Bob, I admit this gen 5 was a first...Kinda why I allowed him to purchase the GM stuff that failed...I did a "little" research to discover the 1037 Felpros, and then wondered to myself why I'd been using the 1017s with the bigger bore?... They always worked, but clearly aren't the best choice for a MK IV with a 4.310 bore..... I had questioned Felpro about this issue a few engines back when both the heads and the block were o ringed and the 1037 exposed portions of the o ring grooves..(No, they were not matched up as a ring, and a receiver groove, just two components that weren't designed to be used on the same engine, bought used).....With any luck at all I'm done messing with the gen 5 deal and can get back to the River Pig boat.....
    Ray
    Jan 2010
    So Cal
