513 Ford
Results 1 to 14 of 37
513 Ford
    Senior Member 69sleekcraft's Avatar
    VA.
    Default 513 Ford
    Forget I Asked
    Would this be a 550 hp 513 or a 750 hp 513 and does it make that power at 5,200 or 6,500 ? Or is this a 514" Ford crate motor ? It's the little details that matter.
    Sleeper CP
    Big Inch Ford Lover
    VA.
    Done
    Quote Originally Posted by 69sleekcraft View Post
    Do not no.The motor was bought from chris the plumber.He did tell me today it was a full roller motor.It came out of a drag boat with very little use. Sorry do'nt no much about it.It is on the way from AZ. now.
    Check with him to see if it has a 3/4 race cam
    Seriously you need to have a bit more info for anyone to give you a good guess. We( brother and I) built a 710 hp @ 6,000 rpm 512" 17 years ago 10:1 comp pump gas. It ran 84-86 no nos and 92 ish with a 200 hp nos system but it turned an A impeller at 6,000 with the nos approx 5,200 off the Nos at 85 in the gullwing.
    Find out rpm range and power estimate and I'm sure there are a few who will give you a good guess.
    Sleeper CP
    Big Inch Ford Lover
    Senior Member eliminator's Avatar
    Roanoke VA
    I think the 513 does not use the 3/4 cam , it uses the full 1'' type to make up the difference on the flux capacitor .
    Spider Monkey Racing
    FRIENDS DONT LET FRIENDS DRIVE EGGBEATERS
    Senior Member 78COLE's Avatar
    Greenville SC
    Quote Originally Posted by eliminator View Post
    That funny right there... I dont care who ya are
    CLASSIC HOTBOATER wideopen's Avatar
    ROANOKE VA
    cris the 513 also used the 1/2 style cam if its a true bay city roller
    it uses a 700 thousands longer lifter to make up the difference in play
    NOW
    if its a 514 you need to check with WARP SPEED this is old school nascar junk
    he worked on these when he was 12 ,they had one in the pulp wood truck down at the saw mill, they used it to run the saw
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Quote Originally Posted by wideopen View Post
    NOW
    High Rock Lake, N.C.
    Let's see, you bought a ford and don't know what is in it Please check your eye hook size on the front of your boat so I will know what size Ford Tow Rope I will need to carry
    If You Can Catch A Cole's Avatar
    Princeton WV
    Default Ford
    What is a FORD motor? In a drag doat? Is this some kind of joke? I thought that they were all in F150 tow trucks.
    San Francisco Bay Area
    Cool
    What can be expected out of a 513 in a 800 pound jet boat. B impeller in a fresh pump.
    Your quesion is very generalized and somewhat loaded, regardless of engine brand.
    You have not provided any details whatsover about the build, so how can anyone estimate performance capabilities? Also, even if the power output was known, the engine might push one 800-lb hull with a B impeller to 77 mph, and another 800-lb hull with a B impeller to 97 mph...depending on overall setup, etc.
    The potential of the engine that you (blindly) bought can better be determined by way of a tear-down, or at least by telling us what block it has, what heads it has, what induction, ignition, etc. I have personally known 500-cube Fords running on carbs and gas (no power adders) that put out just 450 hp, and also have known 500-cube Fords to generate in excess of 1000 hp on just carbs and gas. It's not hard to tell which engine is which when looking them over, but you have provided zero detail, and we need build details to so much as even consider speculating.
    LO
    High Flow Dynamics
    Quote Originally Posted by Catch A Cole View Post
    Where's Red Pearl when I need him ?
    Now what's the record of the Crap Shoot boat ?
    Sleeper CP
    Big Inch Ford Lover
    Thumbs up
    ...a FORD motor? In a drag doat? Is this some kind of joke?
    Sleeper CP
    Big Inch Ford Lover
    Yes, I do believe he is still the record holder in the class.
    LO
    High Flow Dynamics
    Quote Originally Posted by LakesOnly View Post
    LO
    Not only that, but I've been to 5 drag boat races and I think it's won all 5 times, I know it won at least 4 of those.
    S CP
