Do not buy from wright way blower service!
Results 1 to 14 of 61
    Senior Member whiskeybent hondo's Avatar
    Jun 2010
    arroyo grande ca
    Default Do not buy from wright way blower service!
    I purchased a 10-71 mooneyham blower (built by wrightway blower service) off ebay on Jan 29, 2011. The ad said new billet end plates, new teflon strips, new bearings and seal and new anodizing. Listed in good condition.
    In August after finally assembling my motor and putting it in the boat I realized that my mooneyham billet carb adapter would not bolt to the blower! The holes were 1/16 off in every direction. Then I realized the anodizing on the top of the blower was covering up the welding on the case to make it a standard opening blower!
    The ebay ad did not say the blower had inserts, and it did not say the case had been welded!
    I should have filled a complaint to ebay right then. But being a nice guy I did not want to put a bad mark on WrightWays ebay account.
    I called the shop and told Greg Wright that I had to drill a KUHL carb adapter and only use the outside 4 bolt to get my boat on the lake. I then had to change my carb linkage, and could not use my billet are cleaner assebly because the KUHL adapter spacing is different.
    I asked for the top of my blower to be fixed at the end of the season. Greg agreed to fix it.
    After spending $160 to ship it there and back, $250 new stripping (after only 6 hours of use there was 2 inch strip missing) Wright way blower service assured me my blower was fixed.
    Let me ask all of you....DOES THIS BLOWER LOOK FIXED?????
    The threads in the front right hole only go 180 degrees around the hole. The top of the case near the middle insert is cheese graded with a die grinder and was covered with black silicon!!!
    On top of all this my carb adapter still does not fit!
    I called Wright Way blower service to complain and requested a full refund for the blower and I was told no way. Greg Wright told me to ship it back down there so he could weld all the holes and redrill but that I would have to pay for labor and reanodizing the blower!!!! If this was your blower would you send it back?
Name:	no threads!.jpg
ID:	145983   Click image for larger version.
Name:	silicon cover!.jpg
ID:	145984   Click image for larger version.
ID:	145985   Click image for larger version.
    use a BBC to pull a BBC devanwon's Avatar
    portland oregon
    i hate dishonest people/businesses..... i dont think that i would send it back AND pay for the other too.
    the LEAST they could do is fix it and they should take care of shipping. anyways i would file a complaint with the BBB.
    just my .02 cents
    hey
    There is plenty of good Blower guys out there! Hondo Jim took he his somewhere to have a seal changed or something anyways things turned out awesome... I`m sure He`ll post something soon
    BTW - I`m not that happy with my blower either! Good luck
    Kent, WA
    Hud
    Hud is offline
    Senior Member Hud's Avatar
    Wherever Ca.
    Ebay?
    Atlantic Beach, FL
    I used Greg once for a restrip on an 8-71 and it came out OK, but the above example is an abortion. It was a year or so ago when I was there and he works out of his garage; just a small operation. That should be all the more reason, IMHO, that he just swap out the case and make this customer whole.
    Word gets around fast, eh?
    Atlantic Beach, FL
    Quote Originally Posted by whiskeybent hondo View Post
    I know it seems obvious now. But this guy runs a blower service shop and has an ebay business!
    At that time i thought it was safer to buy off of ebay vs the forums because at least then I had ebay and paypal protection.....im a dummy!
    I don't think EBay is the issue; this is 2012! You and I, along with millions of others buy quality products off EBay, new and used, every year. Holley sells off EBay, as do many legitimate businesses. Many small businesses start out in the owners garage, so I mentioned that because small businesses live or die on their reputation and do not have the volume to dissapoint/lose ANY customer...
    The point is Greg Wright has an ongoing business and still needs to protect his reputation.
    You might consider, at this point, taking the blower to a local guy and having it inspected so you have information from an unbiased 3rd party.
    Hud
    Hud is offline
    Wherever Ca.
    I'am just saying if I'm going to spend that much money on something I have to see it 1st.
    Senior Member rocket98's Avatar
    Oro Valley, Arizona
    Sorry to hear you had a bad experence.
    PS I word to the wise.....I hope you have all your ducks in a row. I have seen a few of these threads turn real quick if you have not been completly truthfull about everything.
    They older we get the faster we were
    Jan 2011
    Mickleton, New Jersey
    we do all ours in house. doesn't look hard to fix that one. Good luck
    Smokin Whitie hondo jim's Avatar
    Northener
    littlefield has done the best work for me..blower shop sucks ass had it there twice and ran the same as i sent it to them. Rbs has giving be me great service with parts but havent sent them the blower yet. Psi sucks ass they will rip you off don't send shit there.
    Jun 2010
    arroyo grande ca
    Quote Originally Posted by hondo jim View Post
    thank you for the tip. Rbs has treated me good. I dunno, the whole situation is just a bummer.
    Senior Member littlejockocougar's Avatar
    pleasant hill
    Jr at RBS is a great guy,I try to send him work, but his backlog usually makes him take a little too long. I went to Littlefield last time and got great service,great price, and he did it one day while I was in town. Cant say enough good things about them..
    Jun 2010
    arroyo grande ca
    I agree... thank you for the advise.
