exhaust water leak
Results 1 to 2 of 2
exhaust water leak
    Member 07liberator's Avatar
    May 2012
    Monroe, Ohio, United States
    Default exhaust water leak
    Hi Greg,
    my manifold to riser (snail) where the round gasket goes is springing a really good leak,looking for quick fix I have tried some puttys that harden like steel with some luck, but leak still persist,I'll fix correct when summers over but for now I need a good hard high temp sealant to get me by,any help please let me know ,thanks Jeff
    corona calif
    Default Leak
    Quote Originally Posted by 07liberator View Post
    Hi Greg,
    There is no real quick fix what you fix on the outside can hide the problem on the inside. Bit the bullet and pull the riser off and replace the gasket. You certianlly do not want water being introduced into the log that could cause engine damage.
