Pump takes to long to load
Results 1 to 12 of 12
    Member 07liberator's Avatar
    May 2012
    Monroe, Ohio, United States
    Default Pump takes to long to load
    Why does my brand new dominator pump take so long to load when i first put in the water,I leave it in forward when backing it in but still starts to overheat before the water starts to circulates.....
    corona calif
    Quote Originally Posted by 07liberator View Post
    Depending on the steepness of your launch an air bubble gets trapped at the top of the bowl and will not allow the pump to load, this is usually real bad with a droop snoot and diverter. Try backing in with the reverse bucket wide open if this does not solve the problem there is a small pressure releif that is available that we install on the top of the bowl thus release's the air bubble and allows the pump to load.
    Yucaipa, California
    Hey greg is this someting you can tap and install on mine at the river...easy way for you to make a few bucks and/or bud lites..or a nice big hug?
    I have to sit in the water for sometimes a minute or so to get it to go on my setup....
    1992 Eliminator Daytona 21'
    corona calif
    Quote Originally Posted by Tahiti Boss21 View Post
    No Hugs, No Beer just cold hard cash from you I know history!!!!!!
    Yucaipa, California
    Just put it on my tab and keep em comin!!!
    corona calif
    Default credit
    GS Marine Aha Quin is closed for the winter it will not reopen until May of 2013. Hope this will not inconveinence you and have a great remainder of the season!
    Senior Member riverrat4lfe's Avatar
    Jul 2010
    Hesperia CA
    You were definitely busy this past weekend non stop boats
    Yucaipa, California
    I was just gonna stop in to top off the fluids.....damn dealers.
    corona calif
    Default Top Off
    I know how that goes next thing you know you want an oil change, a couple bloody mary's and the last time you sat down for breakfast you didn't leave until 1 o'clock and had me launch your boat, wipe it down before you would take it on the river!
    Im sure you got it fixed my now but if you havent. If you have a diverter try THis cause mine does the samething thought there was something wrong. before you back it into the water put diverter all the way up and open reverse bucket also some reason it burbs the pump as it goes into the lake. Works everytime for me.
    Yucaipa, California
    Hey i got you out of the knitting class at the old folks home with promise to staff i'd keep you active.....wiping down the boat is one of those activities...
    May 2012
    Quote Originally Posted by Wafobaby View Post
    Thanks for the tip,that seems to be working
