22' Daytona as a jet?
Results 1 to 7 of 7
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Default 22' Daytona as a jet?
    Greg I see on eliminators website that the 22 daytona could be rigged as a jet. Is this true or could it be done?
    Your thoughts on if it was setup correct would 800hp get you in the 80's with a jet?
    I see with motor they claim a 19' daytona is 2000lbs and 1500 more for the 22'
    corona calif
    Default 22 Eliminator
    Quote Originally Posted by Fonz69 View Post
    I see with motor they claim a 19' daytona is 2000lbs and 500 more for the 22'
    Currently the only small tunnel that will accept a jet is the 19 and 21. When the 22 was built we rasied the center sponson for the outdrive and gave it enough height to accomodate a gimble housing with the right X deminsion. I did talked to Bob Leach today and he was going to measure the center keel and see what we would have to do to put a jet drive in the 22. More to come after we measure.
    Frozen Tundra, WI
    Thanks for checking on this, I had a 21 daytona and loved it, Duane at Hi-Tech and Ervin Capps, helped it reach 120mph!
    Have my first son now and would really like a jet with more room then the 21 and a closed engine hatch would help sell it to the wife!
    Cant wait to hear what Bob had to say.
    corona calif
    Ok , the 22 Eliminator is approx 2 inches shy of of being a Jet boat player. Bob said we could make it happen with a slight modification to the mold. But as it stands now the 22 will not work as a jet.
    Frozen Tundra, WI
    Thanks for the response, I am sure re-tooling that mold for a jet would be some big time $$$.
    I did not see the 21' daytona jet pictured in eliminators line-up anymore just the 19'? Are you still making the 21' for eliminator?
    corona calif
    Default 21
    The 21 is still avaiable thru Eliminator.
    Frozen Tundra, WI
    Gregg I got your last pm but I am out of town and my smart phone is smarter then me I think and it will not let me reply to a pm.
    I will pm you back when I get home off my laptop
    Thanks again!
