88 Carrera Eclipse
88 Carrera Eclipse
    Aug 2009
    Default 88 Carrera Eclipse
    Hey Greg
    I bought this Carrera eclipse from riverdad about 3 years ago as a bare hull in pretty rough shape.
    it was set up for a Chevy but I'm a ford guy so a bbf it got. Berk jc ab impeller, split bowl, hph nozzle and new Diverter. I think you had a hand in these back in the day with dennis. What are your thoughts on what it is capable of running? I was at tpm this weekend and I realize I need some more power. (400 ish hp now)
    You recommend a ride plate? Shoe? Maybe have you do a set back?
    Thanks in advance advice chrisadvice chris
ID:	190521   Click image for larger version.
ID:	190529   Click image for larger version.
    corona calif
    Default Carrera Eclipse
    Quote Originally Posted by filterbiz View Post
    Hey Greg
    Chris, Good looking boat, Always like that boat because of the long deck. The Eclipse is a good boat and has a good history. It's bottom was from the Hornet which proved to be a fast bottom in it's day. Another boat that has a similar bottom is the Liberey which has a very fast history in both the drags and espically in circle racing. Generally speaking the bottom is good and straight. Rideplate and shoe is certianlly in your future , along with a subtle set back. I have built a number of these with different kinds of power and all have performed quite well. Speeds of over 100 mph are certianally acheivable.
    Aug 2009
    Greg,
    Thanks for the info!
    I really appreciated it, GS has done several pumps for me in the past. Maybe I will swing by some time to discuss moving forward with a rideplate.
    corona calif
    Default Carrers Eclipse
    Greg,
    Anytime, We have moved to Norco and we are at 1711 Hamner ave. 951 272 6060
