Intake machining for shoe? Any standard dimensions?
Results 1 to 2 of 2
    Senior Member jrider44's Avatar
    Brainerd, MN
    Default Intake machining for shoe? Any standard dimensions?
    Are there any standard dimensions for machining a Berkeley intake(round keel) for a shoe and ride plate? I can do the machining myself but would rather not just wing it if there is a blueprint or drawing I can use. Any suggestions would be greatly appreciated. Thanks, Jason
    ps. What's the difference between a shoe and a back cut shoe?
    1978 Hawaiian Party Cruiser
    Stevens V-drive(sold to bbollig55)
    Spico V-drive
    corona calif
    Default Shoes
    Quote Originally Posted by jrider44 View Post
    We try to use a standardized bolt pattern. With our boats and customer's boats we use a bolt pattern that is utilized by Jack at MPD. California Performance and So Cal Custom Boats all utilize this bolt pattern. I can email you the deminsions that way you will the same as what we use. Each boat will hardware differently so I will start of with a tapered shoe and then make changes accordingly. A backcut shoe is just another tool that we use to acheive optium performane out of your boat.
