Impeller Design
Results 1 to 3 of 3
Impeller Design
    Senior Member SBS933's Avatar
    Jun 2012
    Default Impeller Design
    Greg, What info would you need to to design a curve to have an impeller cut, rather than buying one off the shelf.
    corona calif
    Default Impeller Selection
    Quote Originally Posted by SBS933 View Post
    A dyno sheet is always very helpful, Type of boat, Approx weight of the boat , Current rpm's you are pulling with the impeller you are running. Set up you are running in the boat. Rideplate angle , nozzle angle and nozzle size.
    Jun 2012
    Thanks, I will gather up all the info i can and call your shop.
