How do you determine which Impeller Cut ??
Results 1 to 3 of 3
    Oct 2011
    Sandia,Tx. 78383
    Default How do you determine which Impeller Cut ??
    What cut does one need ? This aspect leaves me a bit fuzzy ! sorry if posted before just bored at work and figured I'd ask !
    http://oathkeepers.org
    corona calif
    Default Impeller size
    Quote Originally Posted by Gopher711 View Post
    When determining a cut on your impeller is usually depends on where you engine makes peak power. Size of boat and weight also play an important part in making you final selection.
    Oct 2011
    Sandia,Tx. 78383
    well that kinda explains things , I was told I could run say a "B" instead of my "A" and spin it faster, which would in turn move more water, thus increasing speed ?
