driveline in the f bomb?
    Senior Member badbug3's Avatar
    Default driveline in the f bomb?
    I noticed in the building pics of the f bomb that you had a align up bar through the mains to the jet drive and i believe you ran a solid shaft splined drive in that boat. Is there a reason you ran the solid driveline instead of a ujoint style shaft in that boat?
    corona calif
    Default F Bomb
    Quote Originally Posted by badbug3 View Post
    We use that for alingment only.When F Bomb was completed it used an h bar driveline with only a Pop Off.
    Are u saying u didnt run this solid shaft in the f bomb, but removed it and put an h bar in the boat?
    corona calif
    Default F Bomb
    When we first put F bomb together a solid driveline was used for a short period of time but ultimately a u joint driveline was used. C G was changed and we could not use a solid driveline any longer.
