Shoe/rideplate help.
    Sep 2009
    rocklin ca.
    Default Shoe/rideplate help.
    Pulled and machined intake for shoe, used a buddy's shoe for mock up and now looking to purchase one for my self. Question is what's best for my boat as a starting point. 1976 18ft bubble deck eliminator. Turbocharged sbc. 600-800hp depending on boost level. Pump is in stock location. Not sure what else is needed as far as boat info? Thanks, Brent.
    corona calif
    Default Shoes
    Quote Originally Posted by brent b. View Post
    Eliminator made two Bubble decks ,one with a radiused keel and the second with a flat keel. Which one do you have?
    Sep 2009
    rocklin ca.
    Round/radiused keel on mine.
    corona calif
    Default Radiused keel
    The 18 Eliminator is a boat because of the strake design on the bottom does not like to run alot of nose attitude. It has a tendency of running a little flatter so a backcut shoe is not where I would start. A flat shoe or a 1 degree tapered shoe is where I would start and see how the boat likes it. Then after you establish a baseline, adjustment can be made.
