Intake install angle
Results 1 to 3 of 3
    Mar 2013
    la habra, ca.
    Default Intake install angle
    I had to remove my intake (old putty) 0n my 1975 18 ft KURTIS 500 jetboat and had it machined for a shoe. when i went to reinstall it i noticed the the center area between stakes (keel) start to come up about 20 in. in front of the intake about 1/4 in. and goes back down to true keel at the transom. becuose the intake goes up in the front it was sitting in the bout at a 4 3/4 to 5 degrees off true keel. is this a problem ?
    should i raise up the back of the intake as much as posable to get the as close to 4 degrees than shim down the the shoe to keel?
    what is the best shoe and ride plate set up to handle this.
    corona calif
    Default Intake
    Quote Originally Posted by kurtisat714 View Post
    Could you please post some pictures of the keel or e mail to my web site. GS Marine.US
    Mar 2013
    la habra, ca.
    greg here is some pics let me now if you need more
