79 Baja 460 Jet
Results 1 to 8 of 8
79 Baja 460 Jet
    Jun 2013
    Default 79 Baja 460 Jet
    removing engine to replace oil pan. I can't pull the u-joint from the pump. This may have never been apart and I don't want to break the aluminum pump. I'm assuming it should slide off of the pump shaft. Thanks
    Senior Member uniboarder's Avatar
    Dec 2012
    It should slide out, its a spline gear. Keep it level and use a bar to wiggle her free.
    corona calif
    Default 460 Ford
    Quote Originally Posted by Chris C View Post
    Is this a 3 point mounting system with a short bellhousing. I t is very critical that the engine almost has to come straight out from the pump . If the driveline gets cocked it makes it hard to slide out. I this also a Berkeley E pump?
    Senior Member TexasJet's Avatar
    College Station, Texas
    How 'bout a pic of your boat. Does it look like mine? I have a 496 Chevy in it.
    Jun 2013
    Default 79 baja 460 jet
    thanks for the info on engine removal. i will let you know how it works out. I will have to find a good pic
    Jun 2013
    It does have a 3 point mounting sys with a short bell housing. I finally got it apart. I had to cut strips of steel and position them along the pump so i wouldn't do any damage. Tapping between the steel and u-joint did the trick. Thanks again, here are some pics
ID:	321265   Click image for larger version.
    Dec 2012
    Why did you have to cut steel to tap on? Just asking.... I have an E pump too. I can pull the motor myself and my daughter can help me line up and drop the motor back in off of a cherry picker. Make sure you liberally anti-seize (silver grade) that spline before you drop her back in! Velcro works well for mounts for us losers who like the motor on the floor in the garage and not in the boat!
    Jun 2013
    Default 79 Baja 460 jet
    I had the engine suspended with the cherry picker and it was straight with no binding of the u-joints. I could not pull it apart. That splined shaft connection was very tight. I'm going to have to clean it real good and make sure it goes on nice before I put it back in.
