engine setting
Results 1 to 3 of 3
engine setting
    Yeah TROU8L3D's Avatar
    Jun 2012
    RIVERSIDE/MORENO VALLEY
    Default engine setting
    Greg or anyone with the right answer if there is one,what is the setting measurement or specs on how far to set my engine back in my pickle fork ,for the best performance or should i leave it alone,
    corona calif
    Default Engine placement
    Quote Originally Posted by TROU8L3D View Post
    How much power are you running, is the hand hole cover outside of the boat,do you feel that it is a stock layed up hull, what is your current engine location from the transom. There is a lot to take into consideration when movinng your engine forward. In the old days I have run well over 130 with the engine setting in the stock location. Moving the engine forward has its benefits but there are a few things to take into consideration before moving.
    Jun 2012
    [QUOTE=greg shoemaker;2335681]How much power are you running, is the hand hole cover outside of the boat,do you feel that it is a stock layed up hull, what is your current engine location from the transom. There is a lot to take into consideration when movinng your engine forward. In the old days I have run well over 130 with the engine setting in the stock location. Moving the engine forward has its benefits but there are a few things to take into consideration before moving.[/
    my hole in jet is inside the boat it's a dominator bowl berkley pump with droop,I got a 514 stroker engine ,aluminum heads .96cc edelbroc heads,hull maybe weighs about 500 lbs
    pickle fork. Nordic looks like a Daytona ,thanx for your time Greg!
