am phibian
Results 1 to 5 of 5
am phibian
    Jan 2014
    Default am phibian
    Hello Greg: i am totally new to jet drives. i was told by california marine in vancouver B.C. that the american turbine i have should drive a 5000LB. 20 ft aluminium hull( like boston whaler or old sea sled hull)up on a plane with a 35o chev with a shorty power glide i hope. what i need is data on installing cooling etc.my hull mount /pickup seems to be OK . there is two fins on bottom of intake plate, can i delete / do i need a screen on intake?
    corona calif
    Default Aluminium Boat
    Quote Originally Posted by rick gray View Post
    Rick, When it comes to plumbing a jet boat you can take water right off the pump. Are running in salt water? If so you can do a fresh water cooling system. The fins are there for 2 reasons , first they enable you to track straight and secondly the help in carving a turn. Do you run in shallow water? The fins can be removed if you are running in shallow water ,but be careful in turning it will act like the boat want to swap ends. I would think you would want some sort of protection so a stock rock grate should be fine.
    Jan 2014
    Default amphibian SUV.
    thanks . i will run heat exchanger. there are skegs outboard so i can cut off fins. can i take water off pump to use in keel coolers or engine heat exchanger.is jet drive self cooling? canm i use take off for hose washdown or? thanks Rick
    corona calif
    Default Skegs
    Can you send me a picture so I can see the back of the boat as well as where the fins are located
    Jan 2014
    Default amphibian jet drive
    here is photo of internal plate at jet drive mount . btm is level for first 6 ft. low angle frame deadrise 3 degrees flat at inlet . see transition plate forward of inlet, recessed 1 inch up into vee btm. as recommended.
ID:	488258   Click image for larger version.
