460 Jet boat jacketed header diagram
Results 1 to 5 of 5
    Member 07liberator's Avatar
    May 2012
    Monroe, Ohio, United States
    Default 460 Jet boat jacketed header diagram
    Hello
    Does any one have a diagram on plumbing jacketed headers on a 460 with no thermostat, I'm running log style now but getting ready to install the headers soon
    thanks
    corona calif
    Default Exhaust
    Quote Originally Posted by 07liberator View Post
    Hello
    thanks
    What exhaust system do you plan on running?
    May 2012
    Lightning
    corona calif
    Default Plumbing
    Lightning
    Out of the pump to the front of the engine , out of the thermostat housing into the water tubes in the bottom of the Lighting exhaust. You can also run a third fitting with a ball valve to a thru hull out the back of the boat if you do not want to run all of the water out of the headers.
    May 2012
    Thanks Greg
    you da man
