Hook or not
Results 1 to 2 of 2
Hook or not
    Sep 2012
    Default Hook or not
    I am going to blue print (straighten) bottom of my radius bottom v-hull looking for some input from you, do I want it perfectly straight or 1/6 of hook engineered in the process of the work? Boat has full set back with ride plate and shoe( clean out outside transom) center streaks end befor intake, boat is 86 apache bubble deck, boat is a two seater and turning a agressor B 5900, thanks.
    corona calif
    Default Hook
    Quote Originally Posted by Bobbylisa View Post
    No mfg ever designed a boat with hook in the bottom. Most of this occurs in post cure. Vertical transom with a horozontial bottom, when the glass cures it draws the bottom up thus you have a hook. As straight as our So Cal Perf. molds are we still blueprint every bottom that goes out the door. With a full set back and the inside strakes ending before the the transom you may have to continue those strakes all the way to the transom so the boat has a place ro take a set on.
