Gen VI 502
Results 1 to 6 of 6
Gen VI 502
    Sep 2014
    Default Gen VI 502
    My crank is at the machine shop now. He's saying it needs to be turned 20/20. My builder is explaining to me that he does not build a motor with a crank turned more than 10/10 due to stress that will be put on the crank etc. the motor will be at 600 hp. I don't want to half @$$ build it. So it's looking like I'm going to be out another 1k on a crank... What's y'all's thoughts? Thanks for the advice.
    corona calif
    Default Crankshaft
    Quote Originally Posted by Texas 272 View Post
    If you were building a stock engine to go in a daycrusier the crankshaft would be alright but whenever you start building power I have to agree with you engine builder 10/10 or standard crankshaft would be my choice.
    Sep 2014
    What's your thoughts on stroker cranks?
    corona calif
    Default Crankshaft
    You would have to buy new rods and pistons. Also is you oil pan clearanced for a stroker crankshaft?
    Sep 2014
    9" pan
    corona calif
    Default Oil PAN
    9" pan
    Are you sure the pan is 9'' deep. 8'' is all that will fit in a jet boat properly. What I'm talking about is the pan rail clearenced for a stroker crank?
