amphibian with powerglide and transfer case
Results 1 to 7 of 7
    Jan 2014
    Default amphibian with powerglide and transfer case
    Greg: an update on my amphibian project> still unsure about true performance ? please critic photos of bow > the idea to allow air trapped under bow to rise up to chine knuckle and be directed aft and outboard to front wheelwells and out exit ports on full fender skirts. i will add fairing bumpers to front of A ARMS hanging down( cannot retract) i hope enough water (no air finds its way to jet intake) there is a slight rocker bottom 5 feet forward of intake ( 3 degree?) should draft to about 12 inch waterline idle, and rise to a plane of ? draft?
ID:	627714   Click image for larger version.
ID:	627666   Click image for larger version.
ID:	627674   Click image for larger version.
ID:	627682   Click image for larger version.
ID:	627698   Click image for larger version.
    corona calif
    Default Amphibian
    Quote Originally Posted by rick gray View Post
    Would you please call me Greg 951 272 6060
    Jan 2014
    Please email [email protected] or phone Rick at 604 9416426. communicate on amphibian topic Thanks Rick
    Jan 2014
    See BOAT DESIgn .com
    Jan 2014
    Gregg: thanks for your input> will try to take photos of transom/bottom ,to get opinions on performance. i assume it will not be a top performer and use more fuel. Rick
    Jan 2014
    Greg; would like to connect with you ,since our phone chat ,I would like to understand your reservations about the water flow to jet/ planing area. only one chance to make mods to improve bottom design. i will take photos of stern/ bottom in take area ,so you may critique. thanks for past helpful comments. Rick
    Jan 2014
    Default bottom shape for planing with a jet drive
    Gregg: a few photos of the bottom shape at transom on my amphibian. i hope gets on some sort of plane attitude ( may not be real efficient) hope any ,pounding is at minimum. see scrieved shape of body plan. compare to photos , your comments count towards my modifying the bottom at jet intake. one photo has tape measure set at one foot height,so you can get some sense of scale. the scrieve is 1/2 breadth( hull is about 7.5 ft wide at transom) on 4 ft wide plywood with tape stretched to 4 ft. the tape near baseline is the shape for 6 feet forward of transom ( transom degree 12 degrees sloped aft) Thanks Rick
ID:	640962   Click image for larger version.
ID:	640970   Click image for larger version.
ID:	640978   Click image for larger version.
ID:	640986   Click image for larger version.
