[Question] aggressor pump , where to lube?
Results 1 to 2 of 2
    2001 cheyenne Splash 555 bosscat_40475's Avatar
    Feb 2009
    Nancy Ky
    Default aggressor pump , where to lube?
    Where do you lube a aggressor pump and what type of oil for a Jet-a-way and how much to add? Mine leaked all the oil out of it. Thanks
    corona calif
    Default Aggressor
    Quote Originally Posted by bosscat_40475 View Post
    There is a grease fitting on the end of the bowl which in order to access you will have to pull your nozzle housing off. Who installed the jet a way. There are few tricks to installing a Jet a way. The inner bearing seal has to be installed the other way so it will hold oil. When installing the slinger ring which is behind the bearing install that with a little silicone so the oil will not seap past the slinger ring. There are two 1/8 inch pipe plugs on the radius of the Jet a way 1 is on top the other is on the side fill from the top until the oil comes out the side and you are good to go. Hi Tech has the oil that he recommends.
