Help identifying year of motor
Results 1 to 5 of 5
    May 2013
    Default Help identifying year of motor
    I don't have the boat nearby so all I have are these pictures. It's in a 89 ultra jet.
    Looking to get the motor rebuilt, due to rod knock.
    You think it would be better to rebuild or swap with a remanufactured?
    Thanks,
    Jonathan
ID:	744489   Click image for larger version.
ID:	744497   Click image for larger version.
    corona calif
    Default 454
    Quote Originally Posted by 89 ultra custom 454 View Post
    Thanks,
    Jonathan
    You have a stock 454 330 hp engine. You have a cast crankshaft,cast pistons, small oval port heads,3/8ths rods , plastic cam gear just a basic 454. What are your future plans with the boat. Do you want to up grade the engine or rebuild it stock?
    May 2013
    Looking to rebuild back to stock and rebuild the jet as well(berkeley je). I'd love to talk about what upgrades we could do without compromising the reliability of the motor. It is our little family boat, not a racer.
    corona calif
    Default 454
    Call me anytime 951 272 6060
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    Give Greg a call. good guy, will point you in the right direction!
    Anyone can pedal a bicycle, can you pedal a flat?????
