1979 Centurion?
Results 1 to 8 of 8
1979 Centurion?
    Member garytcosta's Avatar
    Aug 2015
    santa ana, CA
    Default 1979 Centurion?
    Greg,
    Wondering if you know anything about Centurion boats? Looking at a 1979 18' on CL (pics included). I am curious as to your thoughts on the hull design & performance & how it might compare with other other designs of that were produced around then?
    Also curious as to why there don't seem to be many around?
    Thanks in advance.....
ID:	807706Click image for larger version.
ID:	807714Click image for larger version.
ID:	807722Click image for larger version.
    corona calif
    Default Centurian Boats.
    Quote Originally Posted by garytcosta View Post
    Greg,
    Never known for there jet boats this boat has a shallow V very similar to the Sanger super jet. Good boat for the lower river where the water is always good. We have a couple Sanger's running out of the shop and they run quite well. Have'nt seen this particular model does it have a flat keel or a radiused keel. With all of the 18's around during the 70's and 80's that were being built Centurian was not a not a real popular mfg. in So. Cal thus not a lot of boat sales here.
    Senior Member johnf's Avatar
    Oct 2012
    Default Centurion
    This is a 1978, Full strnger fast hull, Handles great. Has a Delta bottom on this one. No rough water.
    Only seen a couple never in person.
    Aug 2015
    santa ana, CA
    Greg,
    Thanks for your thoughts, & insights. John, thanks for weighing in…
    Not sure if it's a flat or rounded keel. Only briefly talked to the owner, mostly to check if it's still available.
    Smooth water only boat, check. Lower river and local SoCal lakes? Would it be dicey to put that in at Parker, or Needles?
    If I was looking for a boat that would get me on the upper river, I'm guessing by your response that this wouldn't be it?
    Clovis, Cali
    Greg, if it helps with your recommendation. That's the same hull as the Brendella, same bottom as the T deck Hondo jets, I think even Cole sold a few. All of the ones I've seen in person had delta pads.
    Aug 2015
    santa ana, CA
    Quote Originally Posted by propless View Post
    That info helps. I have seen a Hondo t-deck hull, & it seemed to have a fairly large pad. Almost looked like a hybrid flat/vee? If this boat has a similar hull, then it might be a bit of a hand-full at higher speeds?
    Clovis, Cali
    I've never owned one, but a few friends over the years have had the Brendella versions with jets and one Centurion with a V-drive. They always seemed to work well (fast, stable, nice manners) with moderate power. None of them ever had big power so I cant comment on "high speeds". I will say they are small inside, not much room for coolers, lake toys, kids, etc.
    Aug 2015
    santa ana, CA
    Good points.
    After hearing all this, I am pretty sure this boat is not the right fit for me. Probably need more of a 'v' hull to handle slightly more varied water conditions, & a bit more room in the interior.
    Thanks for all the advice!!
