12JG nozzle housing
Results 1 to 3 of 3
12JG nozzle housing
    Cole SS cole ss's Avatar
    Rochester, wa.
    Default 12JG nozzle housing
    Greg. I have a 1990 Cole 20' ss bowrider, 454 stock, delta pad bottom. I have added a river style loader( from you) worked great. Increased speed from 49 to 54. I then added a ( add a shoe and ride plate). That solved a bunch of porpising, towing, and handling problems. Increased speed from 54 to 57. As of now my loader hangs down 3/4", my shoe hangs down 3/8". (Seems to work, can I do better?) Since I have added a ride plate my reverse is lacking and I can no longer use my rudder. I would like to use my rudder since I spent so much time polishing it. I thought about using a drop snoot ( maybe a short one?) I love the way my boat handles now. I only need to move my place diverter back about 2". I know a delta pad works differently than a V bottom. I don't think I need as much lift since I ride on top the water. Should I shoot for a 0 degree pin angle? Should I go a straight or drop on the nozzle? I don't want to mess up my geometry. Thank you, Kimball
    corona calif
    Default PM
    Check your PM,s
    Rochester, wa.
    Default AT drop snoot
    Hello, Greg
    It finally stopped raining long enough for me to get my boat out. I put on a 1" drop AT snoot. I gained about 1 mph more. It did lift the boat more out of the water, moved my water break line about 2' from back. I did not wedge the snoot. I figure I have a 4* up pin angle now. On my 20' Cole delta pad, is my 3/4 deep angle bar loader now slowing me down? Should I cut it to match my 3/8" shoe. So far with my pump additions I have managed to gain 9 mph. Is my boat done? And will I have to work on HP now? I was hoping to gain more from my droop. Hate to tear into motor when I runs so well( reliable). Thank You, Kimball
