lavey 24 nu era
Results 1 to 7 of 7
lavey 24 nu era
    Senior Member Mrs.HLB's Avatar
    Corona, Ca
    Default lavey 24 nu era
    Hey Greg
    Quick question looking at a 2002 lavey 24 nu era with a 496 ho bravo one x and a24 4 blade. The boat has been in the ocean besides the trailer, on the boat itself what can be damaged in the motor or accessories like exhaust water pump etc.from the salt. Will these things be expensive to repair and replace. If so what would in you best est be on the costfor the items that could be damaged.
    Mark
    PS I hope you live longer than I, because you are a great resource for knowledge, repair and parts. There is no BS in that line! I mean that from the heart you always have helped me thank you greg for being that guy
    corona calif
    Default 496
    The 496 has a closed cooling system so the internals of the engine shuould be fine, The exhaust takes all of the raw water so the exhaust manifolds should be looked at but they are also been designed with materials that are salt resistant. Wter pumps and impellers are changed just through routine maintainance. Does this boat come with any service records or atleast any records on what shop has performed the services to this point. Have a shop check it out before the purchase and be sure you take the boat with the owner to the lake and run the boat.
    Corona, Ca
    Not sure if he has the past records. Sceptical about the salt issues though and yes most definetly I would water test it. Or no purchase. Do you offer an inspection of what needs to be inspected like maybe a marine survey to make sure all is well. What would that cost me for you to do this service if you provide this type of work
    Again thanks for your continued technical assistance for this industry
    Mark
    Corona, Ca
    Greg
    What was the cost on doing the inspection I never got an answer on that one.
    mark
    Quote Originally Posted by Mrs.HLB View Post
    Mark
    Corona, Ca
    one last thing is a OMC king cobra outdrive stonger than a bravo 1 and do they make the same gear ratio's and are the parts hardto find for pepairs or add on like drive showers do they even make one for the OMC
    Mark
    PS what HP and tq can the OMC take before failure
    QUOTE=Mrs.HLB;1023139]Greg
    mark[/QUOTE]
    Corona, Ca
    Default lavey in Ocean
    Greg
    Went on line and saw some salt water flush products. If I were to buy the lavey and everthing was ok except for a little mild corrosion could I use that product to save the internal parts from wroughting away. Also is there a spray on metal treatment for the trailer that can stop any furthur damage or corrosion to the trailer
    Mark
    Corona, Ca
    Default P.m.'S
    Greg
    can you check your P.M.'s I need a couple of answeres regarding a couple of different boats
    Mark
