Pump question
Results 1 to 3 of 3
Pump question
    Redding,CA
    Default Pump question
    Hey Greg, I run a motor that makes 550 hp at 5000 rpm. The motor is in a 20' Miller. I was wanting your opinion on an impeller size. I have an aluminum A now but I have an oportunity to pick up a fresh pump with a stainless AB and inducer from a bro. I tach out at 5100-5200rpm now and gps at 74 runnin light on fuel. My pump definately has some time on it so I was hoping to get your thoughts on this deal. Thanks so much. I took some of your advice when I built this 496 stroker and it has been great. Thanks again. Todd Harris
    corona calif
    Default New pump
    Todd The difference between the A verse's the A/B is only going to be about 1 to 2 hundred rpms the good thing is the inducer you will really enjoy the hole shot so I would go for it. Have a great summer!
    Redding,CA
    Default Thanks
    Thanks for the reply. It's golden to have a valued opinion. Were gettin ready to kick this season off up here at Lake Shasta. The lake is 26' from the trees and getting closer everyday. It's the best its been since '05. Have a great season.
