centurion tunnel ?'s
Results 1 to 3 of 3
    sacramento
    Default centurion tunnel ?'s
    is the centurion tunnel like the daytona or like the brendella ? i was told the brendella is narrower. is this good for faster top speed with lower hp? is there a point of maximum speed because of instability on the narrower one? my goal is to have a twin turbo motor with 1350hp minimum & a 500 shot of nitrous.will the centurion do it as safe & what should the speed be aprox? w/wo nitrous ? thanks, turbo wog
    Green Bay Wi,USA
    The Daytona, stealth and cheyanne are more efficient in my opinion. The centurions will run with alot of power. i own a 79 centurion and will own a daytona from greg in the next yr or two. The centurion is narrower with less interior room. My hull weighs about 600 lbs bare.
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    I have a Centurion, Brendella and a Daytona. the Centurion is the same as the Brendella except it is 20' long and both have the rear wings. they are narrower than my Daytona. a 21' Daytona will be hard to beat for the ride and safety. the Daytona will float higher out of the water with less chance of taking a wave over the back. all three can be very fast.
