Ride plate, wedge angles
Results 1 to 5 of 5
    Jun 2011
    Default Ride plate, wedge angles
    Greg,
    I'm new and I'm sure this question has been answered 50k times but here I go. I have a 1975 Miller Jet/Berkley. My boat had 14 degrees of wedge and shot a awesome rooster tail ,very fast, but I want to mellow it out a little, maybe pull a tube for the kids. I took both 6 degree wedges out and put in a 2 degree along with the 2 degree wedge that the ride plate adjusts on. Do I level the ride plate with the intake under the boat or should I set the ride plate 2 degrees less or more than the nozzle. Without any wedge at all where is 0 degrees, intake level, pump flange, transom?
    Does anyone have a picture/schematic of these angles? Sorry for all the questions?
    See pictures(if I did it right)
    Thanks,
    Mike D
ID:	120883   Click image for larger version.
ID:	120884   Click image for larger version.
ID:	120885   Click image for larger version.
    Senior Member motomattox's Avatar
    Apr 2011
    Man....just a thought here but if it's in your budget you should really look into getting a Place Diverter. You will be able to adjust the nozzle angle as needed instantly. Also, looks like your pump is missing the bracket for the reverse bucket cable....
    I remember setting ride plate angle at 4degrees off keel, but I could be wrong. I'm gonna listen in on Greg's explanation
    "Keep talking...it aint often I get to hear a genius speak"
    corona calif
    Default Wedge
    Save your money and buy a Place diverter and you will be a happy camper. 4degree's is a good place to start on the rideplate.
    Jun 2011
    Thanks for the input, I would love to get a place diverter but money is tight. I got a hold of the Miller boat guys and got some of their advice also.
    Thanks again,
    Mike D
    Jun 2011
    Default Ride plate,Wedge
    Here is the latest thing I have done, if it helps anyone. I now have 4 degrees of wedge and will set the ride plate at 2 degrees. Does anyone know where can find 7/16-20 RH and LH threaded connecting rods for my ride plate turnbuckles? The ones I have are too short now that I have removed 10 degrees of wedge. I also need information on how the steering tube adapter seal works and if it needs to stay loose for movement.
ID:	125600   Click image for larger version.
