[Question] GS decal on jet
Results 1 to 7 of 7
GS decal on jet
    Aug 2011
    Default GS decal on jet
    Hi Greg. I purchased my 18.5" Eliminator about three years ago. I noticed it has GS decal on the jet. i was wondering if you would have a record of my boat being serviced/repaired at your shop. What info would you need? it is yellow w/ blue streaks (original).
    corona calif
    Default Eliminator
    I need a little more info. Is it a bubble deck, semi vee, 18 flat deck, 19 foot Sprint, or a 19 Formula by Eliminator. A picture would be very helpful ,or a least the name of the orininal owner.
    Aug 2011
    Default finally some pics
    78 Eliminator 18ftat bubble deck, 454 L29, now has edelbrock air gap intake manifold, 750 holley vac secondaries (non DP) installed sraight outta box, new HEI style dist w/vac advance locked out timed at 33* full advance at 3000 RPM, new electric blue holley pump, all going through ex. logs, berk 12jc-a pump, man place diverter... What can you tell me about this boats service history at your shop if indeed it was ever serviced there. My plans for now are to keep it reliable and as efficient as possible. What mph should i expect? It tops out at 4900 on the water. It also has a plate from rear of boat to the jet (ride plate?) Any reason to install a cam? What can you tell me about this style hull? What octane gas is a good choice for my engine?is my parts combo ok? Any recommendations/advice is greatly appreciated. Any reason for a carb spacer?
ID:	134006   Click image for larger version.
ID:	134007   Click image for larger version.
ID:	134008   Click image for larger version.
ID:	134009   Click image for larger version.
    Aug 2011
    Default recognize this boat?
    hello Greg. If you remember/recognize my boat, let me know. Thanks for any info. Also, what is a good product to use to make the gel coat really shine. Its not oxidized, but i want the best shine possible. what is a good spark plug? does it need to be a marine plug? thanks for any advice. Robert
    Aug 2011
    Default CF number
    Let me know if you need the CF number. I have seen your decal on other jets in the exact same spot. Thanks for any info, Greg.
    Aug 2011
    Default still waiting
    hey Greg. I was hoping to get answer to my question. Thank you. just wondering if you remember this boat and can recall any work you may have performed. would you have any records of it on hand? thanks again....Robert
    corona calif
    Default 18 Eliminator
    Quote Originally Posted by el mojado View Post
    In order to find any info I would need the owner of the boat at the time the work was done. Is this boat a rounded keel bottom or does it have a delta pad which would be flat in front of the intake? The one thing I noticed in the pictures was the bellhousing it looks like a car bellhousing out of a 64 Chevelle with a small block. That item I would remember but as of right now it draws a blank. Greg
