add on ride plate
add on ride plate
    Maple Ridge B.C. Canada
    Default add on ride plate
    I have a 76 18' rogers,450 hp,droop,p/d. running bout 78 mph @ 5400 rpm. I don't want to pull my intake! boat is running great. is an add-on "shoe" & rideplate good money spent , or should I leave it alone. I know it's not a real shoe ,more of a mounting plate for the rideplate. would I benifit from the plate? will the bolt on shoe have ill effects on my ride. I have no pressure readings. thanks
    corona calif
    Default Bolt on rideplate
    Quote Originally Posted by rogerroost View Post
    It has been my experience that the bolt on rideplate and shoe assemblies usually cause more harm than good. The whole trick to installing a shoe is to get the bitting edge above the keel this cannot be accomplished with a bolt on assembly. Save your money and do it right and the benefits will make you a very happy camper. Winter time is a good time for a project like this so keep it in mind.
    Senior Member N2GLOCK's Avatar
    Oct 2010
    I don't know how fast you wanna go, but My 19' Rogers only does high 60's. I have a mild bbc, Berk w/ A impeller, droop and PD. I kinda wish I would've done a shoe and plate last year when I had the jet out but I was on a tight budget then. 78 mph is pretty damn respectable. I'd say leave it alone until you have a need to pull the jet. Just my 0.002
    Thanks guys, thats what i kinda thought. guess I was hoping for a cheap rideplate since i asked i have learn alot on the jet school thread in jet room .
