Carb selection help and opinions pls
Results 1 to 14 of 22
    Member HawaiianPunch's Avatar
    Oct 2011
    Vancouver BC Canada
    Default Carb selection help and opinions pls
    I am running a 468 bbc with 560 lift, log exhaust and 781 heads, air gap intake, 12jc "A" impeller. I have a 3310 750 vac carb ready to go, would that be the best combo or move up to mech second 750 double pump, or 850? I remember someone saying on here there are minimal gains between the 3, I am building a nice cruiser with some balls..steel crank, upgraded rods and valve train. Also what opinions does everyone have on marine carbs, starters, dizzy, fuel pumps versus auto, I am running an open engine. Thx for reading!
    Ok, I'll take a shot. If you already have a good 750 with vacuum secondaries, I'd run it. If You have access to either a 750 or 850 with mechanical secondaries and it wouldn't cost you anything to change, I'd run the mechanical over a vacuum carb on a boat. I wouldn't spend a bunch of money to change your good working carb just to get rid of the vacuum secondaries though.
    As far as "marine" alt, starter, fuel pump, they are a good idea. Again, I wouldn't throw away any good parts just because they are not "marine" as long as you have an open engine compartment. If your engine is closed then I would definitely recommend marine for both safety as well as liability issues. What makes these electrical parts "marine" is they shield the armature so it can't spark and ignite any fuel fumes that could settle in the bilge. The fuel pump will have an extra vent tube that would vent through a clear line to the spark arrestor or air cleaner allowing you to see raw fuel in the line if the diaphragm started leaking.
    If for some reason you had an engine explosion do to fumes being ignited, your ass would be in hot water if they find you don't have marine rated electrical components on your engine, but this is usually only a problem with closed engines. Hope this helps.
    Feb 2012
    OC, CA
    I agree completely to all said and run the 750 you have.
    Oct 2011
    Vancouver BC Canada
    I was thinking the same thing. I do have access to other carbs and I am going to break the motor in on the dyno so i will swap them and see since I'm paying for the time anyways. Just wanted to see if I was on the right track. I'm not too worried since fumes wont build up but I'm not ruling out anything yet. Thx again!
    Senior Member motomattox's Avatar
    Apr 2011
    Quote Originally Posted by icecreaman View Post
    ok, i'll take a shot. If you already have a good 750 with vacuum secondaries, i'd run it. If you have access to either a 750 or 850 with mechanical secondaries and it wouldn't cost you anything to change, i'd run the mechanical over a vacuum carb on a boat. I wouldn't spend a bunch of money to change your good working carb just to get rid of the vacuum secondaries though.
    As far as "marine" alt, starter, fuel pump, they are a good idea. Again, i wouldn't throw away any good parts just because they are not "marine" as long as you have an open engine compartment. If your engine is closed then i would definitely recommend marine for both safety as well as liability issues. What makes these electrical parts "marine" is they shield the armature so it can't spark and ignite any fuel fumes that could settle in the bilge. The fuel pump will have an extra vent tube that would vent through a clear line to the spark arrestor or air cleaner allowing you to see raw fuel in the line if the diaphragm started leaking.
    x 3
    "Keep talking...it aint often I get to hear a genius speak"
    Oct 2011
    Vancouver BC Canada
    Another question, anyone know the hardware required to bolt/attach my Berkley intake to my hull? And the hardware for intake to pump? thx
    Maple Ridge B.C. Canada
    hey Mike ,Don here . are you dealing with jimmy richmond ? if so whats he think? I have an 850 dp you are welcome to take to the dyno. cheers
    Oct 2011
    Vancouver BC Canada
    Yo Don, no I just got it done myself all the machining was already done so I just had it put together with a buddy, but I talked to a few people about the cam and other key things which needed attention. Thx I will take you up on borrowing that carb!
    Feb 2012
    OC, CA
    Default Intake install
    Its not as simple of as your thinking to just bolt an intake in. Do a search on the boards on how to sit an intake. Or call Tom of Jet Boat Performance for guidance or have a pro do it local to you.
    Senior Member bc18's Avatar
    Call c&j engineering that way your not guessing.
    +1 (562) 229-0222
    Senior Member wolfie's Avatar
    I'd go with the 750DP is you have it handy as well. I have a 'cruiser that's stroked with a .570 lift cam. I run a 750DP. I just play around on the lake with it since it's the family boat, so I'm not that worried.
    Oct 2011
    Vancouver BC Canada
    Quote Originally Posted by Ol Blue View Post
    Ok thx Blue I will call around on that one. But as the intake was already on the boat from stock what is my main concern? I haven't changed anything I just wanted to put new nuts and bolts. Am I missing something?
    Oct 2011
    Vancouver BC Canada
    This is the only pic I have of that area..referring to mounting the intake.
    Feb 2012
    OC, CA
    You will notice on the corners of the intake threaded holes. These are for leveling bolts for setting the correct height front and rear in relationship to the bottom of the hull. Also correct measurements from the strakes so its centered. Can't be crooked or to deep or you will have problems. You also need to use Marine Poxy Puddy when setting it in. From the last picture, you pulled the intake out. If the previous holes are still there you can get away with re-using but I would measure to make sure it was centered from before. You will also have a problem with the height for the leveling bolts since the holes in the hull have already been drilled. Best to fill the holes to drill out after setting the intake.
    Not an expert like others here on the boards, but know it is very important when going at high speed.
