[Question] Pop off question
Results 1 to 14 of 15
Pop off question
    Dec 2010
    Sapulpa ok
    Default Pop off question
    How many hits do u get on a full bottle & what size of bottle do u use ?? Thanks Craig
    Atlanta, Texas, United States
    Quote Originally Posted by piston in the wind View Post
    My problem has been more in the remembering to turn the bottle off when not in use. We use a 2.5 lb Co2 bottle on both the jetboat and A/Fuel car. I pressurize the popoff and neutral gate on the jetboat and control the fuel control valve and emergency shutoffs on the A/F. They both will operate several race events.... until I forget to turn them off and they will bleed down in a day or so.
    Gear
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Do u guys who run the river with them just leave the bottle on all day?
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    I turn it off when not in use and might go thru 2 bottles over the entire summer.
Name:	Boat finished 022.jpg
    San Diego, CA
    On a leak free system. I get 10 passes on a 2.5 lb botttle before I choose to refill. You might squeeze out more but why chance losing a run. You might get 12 if you pushed it. Depends how you fill your bottles too. Most of the time you won't get 2.5 lbs in the bottle
    Boat 405.
    Canyon Country, CA
    C'mon. I can get 3 in there
    Concord, CA
    Default bottle
    At the tracks a full bottle will last all weekend. When blasting around at the river or lake, I always bring a spare with me. Sucks to run out.
    I recall one time at Bakersfield when my daughter was driving. Failed to check the bottle, and at the in ramp it was empty. Decided to not tell her and let her run. When she gets in she's telling me how sluggish the boat felt and I just stood there and went "Uh Huh". Ok, I'll fix it.
    Jerry
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    Quote Originally Posted by billet racing View Post
    Jerry
    Your going to laugh, but at the river, and the bottle runs out, just borrow a friends flipflop and wad it up and shove it in the port around the shaft and that works very well in an emergency, but be warned it kinda messes up your friends flipflop
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by FARMER JOHN View Post
    I guess u could make an adapter & a long bolt just remove the #8 fitting and instal the TOOL. Would be good 2 to get back 2 the trailer I'll make em $50.00 ea.
    Beer cans will hold the piston down if you run out of air. Crush two or there and shove it in the pop off and you're dialed.
    Cruising around at the river will sometimes cause the pressure regulator to vibrate loose on the bottle and leak. I shut mine off whenever it's anchored and try to have a wrench handy.
    Dec 2010
    Sapulpa ok
    So I guess u don't wanna buy my $50.00 POS adapter thingy $hit. Thats great now there $10.00 OBO u guyz are kilin me U will still need the wrench. SOOO much 4 gettin rich
    Concord, CA
    Default pop off
    I've used a piece of wood whittled to jam in the opening. Aren't we a classy bunch?
    Jerry
    Jerry
    i once used the draw string on my trunks to hold the reverse bucket open when i ran out of C02. between the string and beer cans i was super classy.
    Mar 2010
    Clarksville, TN
    Default I'm new to this Pop Off Shit
    Mine is Nelson electric Pop Off and have not had the pleasure of using it yet but is the CO2 used to just close it ??? I guess when I fire mine off I have to go back and push it down or use this funky tool doc gave me ..
