Rotten transom I need advice
Results 1 to 14 of 21
    Default Rotten transom I need advice
    I have started tearing into my daycruiser and tonight i discovered the wood in the transom is completely rotted away. My question is can or should this be fixed. Should I just scrap it and count my loses or try to find another hull? The bad thing is I have the complete interior done and ready to go in and the motor is already sitting in it too.
    Senior Member 76ELIMINATOR's Avatar
    Post some pictures of it. Is it the wood that is attatched to the transome that all the wiring and stuff is screwed too? If so, you should be able to CAREFULLY get it out of there and make a new piece out of ply that you have resined and then glassed in.
    Pictures would help a lot to get a good answer and not a semi educated guess.
    RIP CHEWY-- 11/94--12/06
    RIP MIKA -- 10/95-- 5/09
    Cas
    Cas is offline
    Angry American Cas's Avatar
    naw, no need to scrap it. The wood in the transom really doesn't do much unless the transom glass is really thin. Just tear it out and replace it with a size piece you can get to fit, meaning you don't even have to have a piece the same size.
    If the pump is out, it's a pretty simple project.
    Default rotten transom pics
    Here are a few pics of the areas i was poking around.
ID:	8981   Click image for larger version.
    Cas
    Cas is offline
    add a couple of hours for clean up, that's gonna be a messy one. Since it's so bad, you now know that it doesn't have too much structural purpose. You didn't even know it was rotten until you started poking around
    With it being that bad, it's been that way for years.
    Thanks, I'm game. Tomarrow I will start tearing out the old wood.
    remember to resine and glass it so you wont have the same problem again for a long time. I am doing something close to what you are doing . New floor, and i got a little rot in my transom board.
    Inland Empire-Big River
    You may want to PM toddnjuzz - Todd at TRG Fiberglass. I'm sure he can help and offer some sane advice. You may not know what your in for. The pics look pretty bad/messy but it is definately repairable. Good luck.
    We wash our parts in gasoline,
    We drink Alcohol,
    And we go racing with Nitro-Methane!
    Ladera Ranch
    How thick is the glass? If its atleast quarter inch Id just leave the wood out. Unless you have stuff mounted there...You could always through bolt...
    Today I will tear the rotten wood out and see where I am. I'm pretty handy and think I can pull this off. Do you guys think I should pull the pump? The wood all around the pump feels soild.
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I don't think you'd have to pull the pump completely out but the transom housing wouldn't hurt. You could use the exterior of the transom for a rough pattern for the new wood and then it would only be a matter of trimming it down on all ends to fit. You might want to rent this video and see if it gives you any help.
    http://smartflix.com/store/video/134/Transom-Repair
    SR
    SR is offline
    Cajun Member SR's Avatar
    Laf. Louisiana
    If you don't take your pump out,I would atleast mask it off (and anything else that is finished) before tear out and reglassing transom.Your transom issue can definately be repaired.
    Junior Member rockfish71's Avatar
    Smile
    Hello,
    There other things way better than just wood this is what you want to use I did all my strings and trasom with this it will last forever and will not rot check out this stuff.
    http://transomrepair.com/zk/
    West Mich
    Thumbs up
    FIX IT ................ walk in the park , we can talk you right thru it
