Opinion on this cam
Opinion on this cam
    Member DarylP's Avatar
    Jan 2012
    Benton City, Washington, United States
    Default Opinion on this cam
    Found the cam card for the cam that was installed by the PO during the rebuild of my 460. Here are the cams Specs.
    Elgin-1088p
    cam lift Int 280 Exh 280
    Valve lift Int .490 Exh .490
    Lobe Ctrs Int 106 Exh 114
    Adv Dur Int 278 Exh 270
    .050 Dur Int 212 Exh 212
    Adv Timing btc 32 abc 66 bbc 72 atc 26
    .050 timing btc not showen abc 32 bbc 40 atc 8-
    Rest of engine is stock other than bored 40 over. Any Hp guests with this cam?
    Oct 2011
    325-350 hp stock heads, etc
    Orlando.FL
    Good for low torque, RPM 4000 4500
    Jan 2012
    Thanks for the reply back. Will stick with this setup for the season than make plans on upping the torque over the next winter.
