1966 421 HO Pontiac with Edlebrock Wet Exhaust Manifold
Results 1 to 5 of 5
    Junior Member Blue Mist's Avatar
    Mar 2012
    Default 1966 421 HO Pontiac with Edlebrock Wet Exhaust Manifold
    In the process of rebuilding this engine i noticed that my left exhaust manifold has developed a 7 inch crack horizontal within the top accent recess of the aluminum manifold. This appears to be in just the outer jacket of the manifold but may not be repairable. I'm wondering if anyone knows of where a replacement manifold might be found; looking for any helpful suggestions.
Name:	1966 421 HO Pontiac with Edelbrock M3 Exhaust Manafold 2.jpg
    Mar 2011
    This guy might be able to help you out
    http://www.performanceboats.com/boat...e-project.html
    what kind of boat is your pontiac in any pics? Welcome aboard
    Quote Originally Posted by Blue Mist View Post
    The crack visable on the outside can be easily repaired and likely will not even show its the possibilty of an internal crack that I would be concerned with , you may want to consider making a "test plate" to pressure test the manifolds while checking/repairing/testing Tom
    BTW Very cool Old Tri Power setup !
    Now all you need is a old Rayson Craft to put it in.
    Dallas, TX
    Cool to see another Pontiac in a boat. Hopefully you just have a crack in the outer wall and it can be repaired. I have seen two sets of Pontiac logs come up in the last 3 years. They are rare but they are out there.
