BBF cam lift question
Results 1 to 9 of 9
    Jul 2009
    Default BBF cam lift question
    Hi, anyone have any idea what is the max lift at valve for a stock set of DOVE C heads?
    Feb 2012
    OC, CA
    You should call Paul Kane (LakesOnly) on the boards here or go to his site www.highflowdynimics.com You can do a lot with the DOVE-C heads. I'm sure he will recommend to upgrade your studs, rockers, springs and of course push rods. Go bigger on the valves also with port work to maximize adding more lift.
    Pink Taco Reagan's Avatar
    Santa Clarita, California, United States
    R these heads goin on this year Mike?
    Jul 2009
    Quote Originally Posted by Reagan View Post
    I think so! I emailed Paul.
    Nice, I'm tryn to work out the time off for June.
    Bullhead City, AZ
    Quote Originally Posted by Cowboy_Mike View Post
    What springs do you have and what retainers as well as what valves and pistons ? The stock rocker will take .600" lift, I am going to be using a set on my engine for the Parker 300 this season.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Jul 2009
    Quote Originally Posted by Squirtin Thunder View Post
    I will match the springs, and retainers with the cam. They will be stock diameter, with what ever the cam specs out for. I don't if I will have to machine the top of the guides for a desent lift, under .600. I have a few hydronic flat tap. cams in mind to match my pump set up. Compression will be about 10 to 1, 10.5 to 1. Stock 8.8-9 to one pistons.
    Jul 2009
    Default June
    I hear ya. I have a graduation to attend The 1st, and a dinner after. So I am thinking early Sat. morning I will get there. Provided I get the top end done.
    San Francisco Bay Area
    Cool
    Bone stock D0VE-C heads and valve train, about 0.440" lift before you start mashing the OEM stem seals and risking retainer-to-guide clearance issues. After head mods and race setup, the sky's the limit.
    LO
    High Flow Dynamics
