454 or 502 ?????????
Results 1 to 14 of 27
    Mesa AZ hallettss's Avatar
    Default 454 or 502 ?????????
    got a little problem? a buddy of mine blew up his 454 in his jet ,a spun bearings , crank junk. he is debating building a 502 but dosent want to have to buy everything . his pistons ,heads ,rods, cam are all still good from the 454 . Is it worth buying all the parts for the 502 or would it be more benificial to stay with the 454 . some questions are what parts will not fit from the 454 to the 502 . the 454 was 11:1 comp. what will be the hrse power gains . just looking for solid opinions and he isnt building a jet dragboat 60 to 65 mph boat.
    496 or 502? gen?
    502 gen 5 im told oil pan depth is the issue
    He could stroke the 454 to 496. Does he already have a 502 block? I think the head interchanging is somewhat iffy, water jacket issues. May be some one else will chime in.
    i have heard that also
    rollin in the desert Bigern's Avatar
    Mesa, AZ Eastside Roller
    I've got a crank that needs turned
    He could stroke the 454 to 496. .
    He is too cheap to do that
    G H E T T O F O E L I F E
    Quote Originally Posted by Bigern View Post
    You got crank? Since when did you change professions?????
    Hit it where you fit it
    Santee Ca.
    Quote Originally Posted by hallettss View Post
    I have a Gen IV 496 (4,310" x 4.25" ) and it runs hard but........ a 502 with the exact heads , cam ect... will run slightly harder. The larger bore & short stroke is the hot set up for unshrouding your valves and improving overall air flow as well as a decreased rod angle ect..( less stroke can fit a longer rod in a standard deck block)...
    Drag boat or not if a 502 is easy to get rolling I would lean towards a 502. If you have a lot of 454 goods laying around it may make more sense to go that route instead $$$$$.
    Big bore + short stroke IMO is the hot set up for a jet boat, and maybe next time I will figure that out prior to having my motor built..
    Lexington, KY
    Talking
    If I had the money, I would go with the 502. But, if money is an issue (as it usually is) I would go with the 454, especially if you have most of the parts for the 454. Try sticking this thing in the "On the Dyno" section as well.
    My dream engine for my boat is a 502, but that is a long way off in the distance.
    Good Luck!
    HJ
    Good Luck!
    If it is a dream why stop at 502. there are bigger motors.
    Cy
    Senior Member tx-19's Avatar
    wittmann,az
    i have a gen 5 block with gen 4 heads.never had a problem as long as you use the right head gasket.the oil pan was to deep,but milodon make a 10 quart pan for around 300.dooley makes one to.
    Senior Member KLINGER's Avatar
    redlands/ aha quin
    Where Are You Located?? I Have A Gen 4 Crank Just Polished I Picked Up Tuesday That I Was Gonna Use But I Got A Deal On A Steel Crank So I Dont Need It Anymore. Mains Are At 30 And The Rods Are At 20. I Have Clevlite Bearings In Boxes Ready To Go. $300
    Newton Ks.
    Sounds like a decent deal there Klinger.
    H.L. Mencken
