Ratchet question...
Results 1 to 12 of 12
Ratchet question...
    Nov 2011
    Default Ratchet question...
    Does anyone know if I can remove my ratchet, reinstall the bearing cap and the driveshaft.
    I don't know what modifications are made to the shaft during the ratchet installation.
    I need more engine clearance....
    Thanks!
    okie, lake Texoma
    Quote Originally Posted by onalky View Post
    Thanks!
    Depends on what kind of ratchet, you'll need to move the engine back about appox. 3" or have a drive shaft made 3" longer, which ever fits your needs.
    But yes, you can remove the jetaway and reinstall the bearing cap. Not so with the Dons pump release.
    H8-2-W8
    [email protected] first pass
    you can remove the ratchet and reinstall the bearing cap , if it is one of hi-tech ratchets it does not require any shaft modifications.
    B1 Racing cs19's Avatar
    Your suction seal was likely installed backwards when the jetaway was installed just so you know.
    I think its around 4" with a jetaway.
    Chris
    B1Racing.net
    Senior Member bp298's Avatar
    LHC
    you may also going to want to re-pack the bearing...
    Nov 2011
    Default ratchet
    Thanks Guys,
    I need to move the engine back at least 4". I suspect the engine was set further forward as it had a pretty healthy turbo motor in it.
    Judging from the hardware I'd say someone was racing....lol. I am going to sacrifice the ratchet as I don't think TX-20's have a shutdown problem and I am
    not going racing. At least my TX-18 never had a shutdown problem. I'll be keeping it below a hundred anyway as I am too old for this...hahaha. Just helping my 14 year old build a blower motor like I used to when I was a kid. Thanks again!
    Atlanta, Texas, United States
    Thanks Guys,
    On Alky,
    You had not mentioned what type of boat you had, etc. A TX-20, even with a mild performance engine, will perform better with the engine a few inches forward. View this thread from a few weeks ago: http://www.performanceboats.com/jet-...placement.html
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    Thanks Guys,
    If youre selling the ratchet, I know a guy looking for one.
    Nov 2011
    Default motor placement
    Quote Originally Posted by Gearhead View Post
    On Alky,
    Yea, the boat already has 4 inches added to the driveshaft which is about what I had in my old TX-18. With the ratchet, it appears to be about 8 inches forward.
    I am hoping that the 4 inch driveshaft will be enough for the backseat to clear the blower belt. Thanks for the info..
    Anaheim Hills
    Thanks Guys,
    So how much do you want for it?
    Feb 2012
    OC, CA
    I think taking the Jet-away out is a mistake. You will miss it.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Quote Originally Posted by Ol Blue View Post
