The only exception when separate front motor plates might not help....
Results 1 to 12 of 12
    San Diego, CA
    Default The only exception when separate front motor plates might not help....
    Boat 405.
    Senior Member isanger's Avatar
    Sep 2011
    Silverdale/Ellensburg Wa
    That'll buff out!
    Studded v6... gm Vortech? What did this thing come out of kjell?
    San Diego, CA
    i believe it was a buick v6 24 lbs of boost.
    Boat 405.
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    Default Busted
    That Dude that fixes BRONZE impeller should be able to repair that good as new. Seriously I have never seen one that bad. Did the crank break first?
    Ron
    One less DEALER means more DISCOUNT for you
    San Diego, CA
    oddly enough he said it was running but making a lot of noise, lots of oil mess. He said rotator was ok, not even a spun bearing
    Boat 405.
    El Cajon , Ca
    So the oil pan and intake were holding it together and it was still running?
    LaGrange GA
    That's a 109 casting out of an '86 or '87 Buick Grand National or T-type. Takes waaaaaay more than 24#'s to make them act up, but damn. That's some serious splittage. I can't imagine the amount of detonation to make that happen (and how bad ass the pistons are to let it get that far). Normally the 4bolt head sealing won't let it get to that level.
    Obivously he's a 2 stroke guy. He just got confused and thought he needed to split the case to access his crankshaft.
    Senior Member wolfie's Avatar
    Wow, that'll ruin a good day of skiing!!!
    LaGrange GA
    40PSI 29* of timing on 93 pump gas
    Ultimate 109 carnage | TurboBuick.Com
    Said he didn't even spin a main bearing and the rotating assy is fine! That's some nice luck.
    San Diego, CA
    Cool, I knew someone had more details on it.
    Boat 405.
    The Right Coast/SE-PA
    JB Weld...what else ya got?
