boat hull color on the inside?help!
Results 1 to 14 of 14
    sacramento
    Default boat hull color on the inside?help!
    i need some help figureing out what to do with the inside of my boat.i did some experimenting with resin color, i dont like the yellow ,or blue. i don't want to use bedliner either.the yellow might look o.k if i go over it with paint for a shine?........anybody have any pics or any ideas for my hull? thanks, turbo wog. i was thinking blue & black carbon fiber but the inside i believe is too wavey to look good & i am not sure i want to deal with the extra labor.
ID:	153920   Click image for larger version.
ID:	153921   Click image for larger version.
ID:	153922   Click image for larger version.
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Sand it down and flow coat it. It will look good.
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    sacramento
    Quote Originally Posted by jyeager View Post
    repairs from the bottom will show.
    Senior Member Mojave85's Avatar
    Boise, Idaho
    I just re-did the bottom in my daughters boat and painted it. Take a look at this thread - New Project Cole Full Stringer here in the jet section for pictures.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    flow coat it black do not paint or bedliner it that crap will look like hell after a season and be heavy as sin
    Senior Member wolfie's Avatar
    Quote Originally Posted by HBInHeat View Post
    x1000 on the bedliner, never use that crap on a boat. Some dipwad screwed up a perfectly good SWTD by using bedliner on the deck.
    Sep 2010
    Quote Originally Posted by wolfie View Post
    Yup! That yellow thing keeps coming back.lol but sand the whole inside as flat as you can and flow coat.
    Anaheim Hills
    Flow coat it! Don't paint it! You'll regret it.
    sacramento
    not pretty but ready to rock & roll. i'll finish the polish stuff when i get a chance.gonna get this bi*ch running soon.
    sacramento
    Default alittle progress
    finally drilled the first holes in the stringers. had to plan things out .all the blue tape was to mark rail kit so if it moved when pulling motor i would know, & timing cover i used a degree level on it to check motor angle to pump ,didn't want to schratch it up,& fuel pump was in & out so much i didn't want to damage that either
ID:	162052   Click image for larger version.
ID:	162053   Click image for larger version.
ID:	162054   Click image for larger version.
ID:	162055   Click image for larger version.
    Senior Member md-11mike's Avatar
    May 2012
    Thousand Oaks Ca
    Quote Originally Posted by NiceGuyEddie View Post
    I like this idea best. Nice to see what going on with the wood underneath.
    Aug 2009
    Santee, California, United States
    Default boat
    i sanded on my for weeks i think then my cousin laid carbon fiber down and it turned out great. u will be happy if you spend the time now while its stripped down. and dont be in a hurry. good luck
    Senior Member brgrcru's Avatar
    Montrose
    carpet
    sacramento
    Quote Originally Posted by turbo wog View Post
    posted these in the wrong thread
