Water to headers
Results 1 to 9 of 9
Water to headers
    Default Water to headers
    Would like to run water to headers, need some information where is the best place to pick up the water. At one time the headers had water run to them but when I bought the boat I got the lines but they were not hooked up. It looked like they were run to the front of the motor, at the floor there is a T that runs water to the front of the motor. Would it be best to run a T off each of these lines? Any information would be appreciated. Thanks
    Apr 2009
    Default Header Water
    Bassett makes a tee you can install that has a spring and a chk. ball in it so you don't put to much water to the headers, you would tie it into your leaving water with a ball valve in front of it to help adjust the flow and volume of water to your headers.. Note be careful if your Cam does not have alot of overlap. You need to be very careful not to have alot of water in the headers at Idle as it will get sucked in the exhaust port and cause damage to the engine..Hope this helps..
    Quote Originally Posted by mrmaxum View Post
    There are multiple methods of simple plumbing for your headers the very simplest is on our site as well as otheres here , the easiest is to take engine water from the "divider T" (similar to a thermostat housing) , typically these have two outlets , one would go to your "bassett/rewarder T" the second would go to an overboard "dump line", we like to plumb a control (lever ball valve) between the divider and the T valve to control water flow attached is a link to a basic diagram feel free to call for plumbing help Tom
    header install help .... Jet Boat Performance, Jet Boat FAQs diagrams, Impeller charts,
    Senior Member Mojave85's Avatar
    Boise, Idaho
    So I am confused. Does the gate valve go in the dump line overboard or in the line to the headers from the bassett t?
    Quote Originally Posted by Mojave85 View Post
    Some run gate valves , after the jet output, before the T valve and at the dumpline to gain max control Tom
    Default T stainless control valve
    Where can I buy T stainless control valve?
    Feb 2012
    OC, CA
    You can get it from Tom at JBP. You can get a Gate Valve that goes at the pump at your Hardware store. Gate is better than ball valve to use.
    Jan 2012
    lake Charles, Louisiana
    I have a basset t with a new spring and check ball, 50.00 will buy it if interested,
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by Ol Blue View Post
    why?
