Berkley ID
Results 1 to 2 of 2
Berkley ID
    Apr 2011
    Default Berkley ID
    My boat has a 12JG-A, how does this drive compare with the other model Berkleys? Boat is a 21', is this the correct setup, is there anything I should do for maintenance? It does have a diverter, are there any "standard" tricks for setup I should be aware of? Thanks
    Not much has changed in basic Berkeley for a long time , that 12JG is the cream of the crop and works well in stock form with power up to 400 ish , what you need to do is going to be dependant on what you want from the boat , how much power you have etc Tom
