14qt pan oil pump pickup question.
Results 1 to 3 of 3
    Senior Member desrtrat256's Avatar
    San Diego, CA
    Default 14qt pan oil pump pickup question.
    Is there a certain pickup I need for a 454 to run a dooley 14qt pan? been trying to research it with little to no luck. The stock pickup will not clear the baffles. Thanks
    You can order the correct pickup from Dooley. Easier than screwing around trying to find a stock one that will work. The Dooley pickup is a nicely made piece. I run the same pan and went through this exact dilemma several years ago.
    San Diego, CA
    Thank you sir. I will be calling them monday morning.
